1. AC Question's Avatar
    I have just gotten a Droid Bionic phone and only have had for about 3-4 months now. I had gotten it from a friend who had gotten an upgrade so she did not need it anymore. I set it up as a prepay with Verizon and everything was fine for a bit... The first thing to start going wrong with it was the camera, for some reason I could not get it to work for anything. That is when I did the FIRST factory reset. It worked once for a bit then it stopped working again. Done the factory reset again, but no luck. So I just gave up on fixing the camera... From there that is when the phone started to reset itself at random times. Like if I was about to make a call, it would freeze then reset. Also, there would be times that I would have to click an app many times before it would open cause it would keep closing itself. It would do this quite a few times then be fine for a few days...
    Well today when I got up I went to check my text msgs, it froze. Then went back to the home screen, but everything was black in the background. I tried to turn it off, but instead it reset itself again... but it stayed that way for three hours. So I decide to pull the battery out, put it back in and turn it on. Same thing... So now it is stuck in a Boot Loop.
    I have gone to the recovery and wiped the cache, wipe data, and done the factory wipe and STILL no luck...
    I have looked on quite a lot of sites since today and I'm at my wits end... Please help, I don't have the money right now to just go out and buy a new phone right now. I want to know if there is STILL A WAY to fix this problem.
    04-24-2015 04:02 PM
  2. Rukbat's Avatar
    If it's a firmware problem, you can reflash the ROM. If it's a hardware problem you have to replace the bad hardware. There's no telling which it is without having the phone in hand.
    04-24-2015 10:17 PM
  1. Touchscreen is sluggish since 5.0 update.
    By maya707 in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-03-2015, 09:47 AM
  2. What do I need to connect my S3 mini to hdmi?
    By AC Question in forum Samsung Galaxy S3 Mini
    Last Post: 04-24-2015, 05:08 PM
  3. Slow response Galaxy S5 when in call
    By DaGbyte in forum Samsung Galaxy S5
    Last Post: 04-24-2015, 02:47 PM
  4. Replies: 1
    Last Post: 04-24-2015, 02:31 PM
  5. music on sd card will not play in music app
    Last Post: 04-24-2015, 02:10 PM
