1. AC Question's Avatar
    Bought a Polariod 8 Android pad from Asda for not much money.
    Works fine, runs Showbox a treat so that's all good.
    Bought a Google Chromecast dongle, it connects to TV and does what it says, except, once connected, the Polaroids screen breaks up as if its running too high a resolution. But, a cheap and cheerful EZCast dongle works fine. Anyone any ideas?
    04-25-2015 03:01 AM
  2. Rukbat's Avatar
    The tablet isn't compatible with Chromecast. (See Chromecast mirroring.) You could try rooting and changing the screen resolution, but that's going to be trial and error, and you may set a resolution that won't work on the tablet, so you'd have to do a factory reset from recovery.
    04-26-2015 04:16 PM
  1. Replies: 8
    Last Post: 10-23-2015, 10:03 AM
  2. Google play keeps turning on and draining battery
    Last Post: 04-25-2015, 08:28 PM
  3. Replies: 2
    Last Post: 04-25-2015, 07:55 PM
  4. Replies: 0
    Last Post: 04-24-2015, 09:13 PM
  5. Replies: 0
    Last Post: 04-24-2015, 08:51 PM
