1. AC Question's Avatar
    My S4 battery is draining supper fast. After fully charging the battery it only lasts 4 - 6 hours. When I go to the battery usage center, it says that the major user is the Android OS. Is there something going on in the background I can shut down to stop the OS from using so much battery?
    thanks
    04-25-2015 07:32 AM
  2. belodion's Avatar
    Welcome to Android Central.
    Is your phone waking frequently, especially overnight? Try a wakelock-detector-type app to find out what's going on.
    Often, a simple Power Off and Restart of the phone will fix Android OS excessive battery use.
    You may also choose to restrict background use in your app manager, although this needs to be done with due consideration of the effects.
    A poor radio signal will also draw heavily on the battery, and may be having that effect in tandem with Android OS.
    Let us know if you want further advice on battery-saving.
    04-25-2015 08:21 AM
  1. How can I get my CUBOT P6 to turn back on?
    By ktdolly in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-13-2015, 01:43 AM
  2. Overnight battery drain
    By Erm10 in forum Samsung Galaxy S6
    Last Post: 04-25-2015, 02:46 PM
  3. where do i find my call blocking with the upgrade
    Last Post: 04-25-2015, 07:02 AM
  4. My Z Ultra wont turn on after activating Ultra Stamina Mode helpppppp
    By Hamed Alipoor in forum Sony Xperia Z Ultra Rooting, ROMs, & Hacks
    Last Post: 04-25-2015, 06:36 AM
