A
AC Question
I've been searching the internet for two hours but I can't fit a solution... Boost Mobile is closed today too so I can't go in to have it looked at for another 24+ hours.
Yesterday I hooked my s3 up to the charger when the battery was around 20%. I continued to use it and noticed it wasn't charging at all. It would go up a percent if I put it down for a few minutes but that was it. Otherwise it would slowly go down one percent at a time. I plugged it in to charge overnight when I went to bed (it was still turned on). When I woke up, the light was green which usually signals the battery is at 100%. I used it for about 30 minutes straight and all of a sudden I noticed it was down to 30%. I restarted my phone thinking it was a problem with the indicator. When it came back on, it was at 20%! I turned it off again and took out the battery. When I turned it back on, it was then down to 9%. Going off the advice of other forums, I drained it down to 0% and then plugged it in and now I'm leaving it alone to see what happens.
Is there a fix for this? Is it my battery or my actual phone? I did the spin test and my battery is not bulging. I also inspected my charger and my phone and both are fine (I also tried a different charger and a different outlet to no avail). I've only had this phone for about 10 months. Help!!
