1. AC Question's Avatar
    I have a new elipsis 8 tablet from verizon. Strange issues with audio jack. External speakers work fine however when i insert headphones or an aux cable the following occurs:
    1. Apps like youtube or slacker immediately stop playing and then will not play after pushing the play button.
    2. Extreme Static and crackling when aux cable inserted.
    3. Will work for a few seconds with cable then audio realted app will crash or stop playing and wont play after pushing play again and again.
    4. After removing the aux cable... apps will not play and have to be restarted or device has to be rebooted. Depending.
    THIS IS THE SECOND TABLET with the same exact issue. Any advice would be great.
    Its 4.4.2 btw.
    04-27-2015 02:49 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It sounds like it's not an issue with the specific headphones, since it also happens with Aux cables. My guess is that it's a faulty jack (and maybe it's relatively common with that device), or there's some kind of firmware flaw.
    04-28-2015 12:00 AM
  1. Music player issues
    By Greg Carl in forum Samsung Galaxy S6 edge
    Last Post: 05-01-2015, 12:38 AM
  2. Can I get some help with the difference between skins?
    By rckymtntim in forum HTC One M7
    Last Post: 04-30-2015, 11:25 AM
  3. swype / textra issues?
    By Delirious D in forum Sprint LG G2
    Last Post: 04-27-2015, 11:11 PM
  4. Help... Shattered Screen! How much to fix?
    Last Post: 04-27-2015, 01:18 PM
  5. i9300 w/ CM11, Severe Battery Drain, Please HELP!
    By CarlosMBM in forum Samsung Galaxy SIII I9300
    Last Post: 04-27-2015, 10:39 AM
