1. AC Question's Avatar
    I'm starting to develop a device, but I'm still new to the Android and don't know if it is possible to power it through the MicroUSB. I have measured the voltage of the MicroUSB pins, but just to find out that there was no signal there. So is it possible to do this? If so, do I need to enable it through the software or is there some other easier way?
    04-27-2015 06:43 PM
  2. Rukbat's Avatar
    Short pins 4 and 5, and you should find power on pins 1 (+) and 4/5 (-). That's how OTG works - the direction of the power pins is reversed (which is why you can't charge the phone when using OTG). It also converts the phone to USB host mode, so if you need the phone to be running data normally, and to be outputting power, you can't do it. If your device is like a mouse, keyboard or memory stick, it'll work.
    Felipe Thomas likes this.
    04-27-2015 11:53 PM
  1. How do I connect my Trio to my tv using an hdmi?
    Last Post: 06-01-2016, 12:02 AM
  2. Lollipop update fails to install
    By pger555 in forum Samsung Galaxy Note 4
    Last Post: 04-28-2015, 12:09 AM
  3. Windows dose not recognize this device ( S3 GT-I9300) RNDIS+DM+MODEM
    By Muhammad Sadaqat in forum Samsung Galaxy S3
    Last Post: 04-27-2015, 10:19 PM
  4. Where to find back up photos?!!!
    Last Post: 04-27-2015, 07:00 PM
  5. Why did my phone icon on the home page change to the clock icon?
    Last Post: 04-27-2015, 06:55 PM
