1. Voika's Avatar
    Hi,
    I have a Nexus 5 running Android 5.1
    Since yesterday my Bluetooth, Hotspot and WiFi won't turn on anymore.
    Bluetooth just switches itself off again when you try to switch it on.
    Hotspot just doesn't even let you switch it on, it just grays out when you click it.
    And for wireless it keeps hanging on "enabling WiFi" but even after 10 min of waiting it's still not switched on.
    I've rebooted the nexus several times already which didn't fix the problem. Also Google doesn't give many suggestions on this particular problem so I'm a bit stuck.
    Anyone any ideas on how to get this fixed without reinstalling Android on my phone?
    Thanks in advance.
    04-30-2015 01:21 AM
  2. AngryBaby's Avatar
    Having the same problem. Rebooting and factory reset didn't work (running stock 5.1.1), can't find a solution online. This only started happening within the last 3-7 days. Wifi, bluetooth won't connect (frequently turn themselves off just after switching on) and hotspot simply won't start at all. LTE and 3G radios seem to be working normally. Never flashed any ROMs to this phone, it is completely stock and no drops, damage, etc.
    If anybody found a solution I'd appreciate the heads up.
    08-10-2015 08:05 AM
  1. How do Nexus 6 owners deal with uneven lay on table design
    By sulla1965 in forum Google Nexus 6
    Last Post: 05-05-2015, 08:13 AM
  2. SD Card lock still an issue with Android L on Galaxy S4?
    By RJ Phillips in forum Android 5.0 Lollipop
    Last Post: 05-04-2015, 11:21 AM
  3. Replies: 1
    Last Post: 04-30-2015, 01:11 AM
  4. Replies: 0
    Last Post: 04-29-2015, 11:27 PM
  5. Why does my sync turn on and off for my email?
    Last Post: 04-29-2015, 10:56 PM
