1. AC Question's Avatar
    Hi, while adding some apps to the homescreen on my Sony Tablet (Androit 5.0.2) the homescreen page indicator (dots) have moved from the bottom of the homescreen to the top. This is driving me crazy as I can't figure out how to move the indicator dots back to the bottom. I am not using any homescreen customization app.
    Thanks!
    05-03-2015 09:41 AM
  2. Serio Perta's Avatar
    Have you removed google search bar from the top of the home box, or disabled google app in the apps menu? If so enable google app and go to the home screen, hold down the home screen until you get the option to add widgets apps etc, and at the top of the screen you can select show google toolbar. This put the 3 dots at the bottom of the screen again for me
    06-13-2015 07:51 AM
  1. What is the best tool to make a Restaurant Menu App?
    Last Post: 07-20-2016, 09:18 AM
  2. Stump remote download on to my devices HELP
    By mdaniellej in forum LG G3
    Last Post: 05-03-2015, 02:52 PM
  3. Replies: 0
    Last Post: 05-03-2015, 09:06 AM
  4. How to toggle between applications in galaxy edge ?
    Last Post: 05-03-2015, 09:05 AM
  5. Why are my ringtones playing constantly when connected to Bluetooth?
    Last Post: 05-03-2015, 09:03 AM
