1. AC Question's Avatar
    Hi all android developers.
    Hope I'm on the right forum.
    I would like to use the signal of baby cry detector on my other device which include bluetooth.
    Once the crying was detected, I would like to receive some signal on my bluetooth, stand alone device.
    Will be happy receiving your solutions.
    I'm using Samsung S5.
    Thank you in advance,
    Dima
    05-04-2015 02:31 PM
  2. Rukbat's Avatar
    Assuming the monitor uses Bluetooth (not all wireless communication is Bluetooth), and assuming it uses a profile that the stand alone device also uses, just pair them according to the instructions in the monitor's documentation. Then, when you want to use the monitor turn it on and the other device should connect to the monitor unless it's already using that profile on another source. IOW, if the monitor used a media profile, and you're using Bluetooth headphones to listen to music on the stand alone device, it won't switch to the monitor, you'll have to turn off the headphones first. (You can't have 2 devices using the same profile in Bluetooth.)
    05-04-2015 11:05 PM
  1. Replies: 1
    Last Post: 05-30-2015, 09:44 PM
  2. Sony Z3 and Quick charge 2.0
    By jcdub in forum Sony Xperia Z3
    Last Post: 05-07-2015, 01:42 AM
  3. how can i permantley delete text messages from samsung s4
    Last Post: 05-04-2015, 07:12 PM
  4. Media volume resets when I turn on bluetooth earpiece
    By mistyisland in forum Samsung Galaxy S6
    Last Post: 05-04-2015, 05:21 PM
  5. Xperia Z2 vs Galaxy S5, What is the best camera phone?
    Last Post: 05-04-2015, 02:10 PM
