1. AC Question's Avatar
    So, my LG Optimus L90 phone had about 60% free storage space before the lollipop update, but now it says I only have 6% free after the update, and I can't install anything. I've cleaned the cache, restarted the phone, but I don't know how to fix it. Any suggestions?
    05-04-2015 03:17 PM
  2. JamesRodriguez10's Avatar
    Reset your phone
    05-04-2015 04:16 PM
  3. vivek panwar's Avatar
    D problem with Lollipop is, its using ART instead of earlier Dalvin so its natural that apps size will automatically increase n thats what Google has intentionally done in Lollipop for increasing speed n battery.
    Problem is, current mobiles hv only 4gb out of 8gb to users. After Lollipop manufacturets will bound to give more GB. N normal mobiles will now come with 16GB internal memory.
    Coming to ur question. Actually we cant do anything if ur updating L90 to lollipop. U can move as many apps to SD card as possible n keep all data on SD card.. N lets wait for LG to provide some update which increase our L90 internal memory from 3.8GB to atleast 5GB out of 8GB.
    06-07-2015 12:52 PM
  1. Replies: 7
    Last Post: 02-21-2016, 04:55 AM
  2. Replies: 1
    Last Post: 05-04-2015, 11:05 PM
  3. Replies: 1
    Last Post: 05-04-2015, 06:52 PM
  4. What are the bases of choosing a compatible ROM to flash?
    By Aserar in forum Android 5.0 Lollipop
    Last Post: 05-04-2015, 05:24 PM
  5. Not enough time to use fingerprint scanner
    By jstwondrng in forum Samsung Galaxy S6
    Last Post: 05-04-2015, 03:58 PM
