1. AC Question's Avatar
    i bought samsung 16gb sd-card and i am put the files, but all files are changed other format like òΣéB8c±Ü.~s
    i also done lots of format that sd card also formatted but again and again the same problem happened.
    please anybody answer to me what is the solution for that problem.
    05-07-2015 06:05 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! First, where did you buy the card? From a well-established store, or from a random seller on eBay? Counterfeit cards are pretty common. Use SD Insight to see if your card is what it claims to be.
    How did you copy files to the card? Was the card inserted into the computer's SD reader, or into the phone, with the phone connected via USB? Were you using Windows Explorer to copy?
    Do the filenames actually change to Greek text, or is that some typo on your end?
    05-07-2015 05:30 PM
  1. How do I get into my Galaxy S3 when I have the wrong password?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 05-07-2015, 05:38 PM
  2. Replies: 1
    Last Post: 05-07-2015, 05:32 PM
  3. Samsung S4. How do I remove Mobogenie?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 05-07-2015, 08:12 AM
  4. Can I update my Samsung Galaxy S4 software after root?
    Last Post: 05-07-2015, 08:08 AM
  5. can I copy this feature to other decive?
    By Joya A in forum Ask a Question
    Last Post: 05-07-2015, 07:17 AM
