1. Jason Ibarrondo's Avatar
    I have a Alcatel one touch evolve 2 but its been threw a lot I've dropped it with a case on it and after the WiFi problems I got some water in the charger port it did not work for some time then I opened it up not touching anything and I used the blow dryer to dry The charge port I put it back together than I worked but I had WiFi problems before and after the water thing happened but the water then not spread any where the water damage stickers were still white but know I've been having a WiFi problem I connect to my own WiFi then two seconds later it disconnects randomly this happens EVERYWHERE am not sure if a WiFi cable is loose or if I need to buy a new phone
    05-10-2015 01:53 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Given the water exposure, all bets are off--there could be any number of damaged components inside the phone. See this guide: http://forums.androidcentral.com/amb...e-got-wet.html
    05-11-2015 01:32 AM
  1. Why does my WiFi keep turning on?
    By TextMeMaybe in forum Samsung Galaxy S5
    Last Post: 05-12-2015, 02:55 PM
  2. no service problem on note 3
    Last Post: 05-10-2015, 12:28 PM
  3. problem with calls
    By BBguy85 in forum Samsung Galaxy S6
    Last Post: 05-10-2015, 12:16 PM
  4. Replies: 0
    Last Post: 05-10-2015, 10:56 AM
  5. Replies: 0
    Last Post: 05-10-2015, 10:40 AM
