belodion Co-Ambassador Team Lead Moderator Jun 10, 2014 39,389 254 83 Visit site May 11, 2015 #2 It will need the attentions of a repairer. There's nothing simple you could do to put it right yourself. Posted via the Android Central App Upvote 0 Downvote
srkmagnus Retired Moderator May 23, 2010 13,434 210 0 Visit site May 11, 2015 #3 AC Question said: Screen turns on can't see anything Click to expand... Is there any visible hardware damage (e.g. screen shattered)? It seems like there is damage to the internals, possibly even the LCD panel, which may need to be replaced. Upvote 0 Downvote
