1. AC Question's Avatar
    Last night I was listening to some music on my phone and I realized that it was hot but it usually does so I did not worry. Then I plugged it in because it would not charge. For example I had it plugged in for 5 hours and it had charged less than a quarter. But I plugged it in and set my alarm then went to sleep. The next morning when I woke up I realized my alarm didn't go off. I thought it was way before it was 9:00 so I reached under my pillow (that's where I put it so it will wake me up) and I remembered it was not there but my bed my burning my hand so I reached inside my pillowcase and there was my phone but that burnt my hand even more so I pulled it out and I unplugged it. I tried turning it on but it wouldn't. I don't know what the problem is so could you please help!!!!????
    05-21-2015 07:25 AM
  2. mrsmumbles's Avatar
    Hi, what phone do you have? It sounds like the battery may be damaged. If you can replace it that might be your best bet.
    Golfdriver97 likes this.
    05-21-2015 08:44 AM
  1. Replies: 2
    Last Post: 02-08-2016, 06:02 AM
  2. Replies: 1
    Last Post: 05-21-2015, 10:49 AM
  3. Amazon.co.uk hav ethe firephone at £99 - is it worth it?
    By Horaland H in forum Ask a Question
    Last Post: 05-21-2015, 10:48 AM
  4. How can I get my HTC One X to power on?
    By AC Question in forum HTC One X
    Last Post: 05-21-2015, 10:45 AM
  5. Replies: 1
    Last Post: 05-21-2015, 08:50 AM
