1. AC Question's Avatar
    My Nexus 4 was plugged into my cigarette lighter charger and when I picked it up it was too hot to handle and the screen went blank. When I plugged the charger back in the red light went on an the screen stayed black. After it cooled down it worked fine. Does this mean I have a defective charger>
    05-27-2015 01:35 PM
  2. Rukbat's Avatar
    Could be. Or a short somewhere in the phone. Replacing the charger is cheaper than the labor cost of determining whether the one you have is bad. (Most "dollar store" chargers work fine. I've been using 2, one in each car, for a few years. Only 1 Amp on mine, but I just want to keep the battery from discharging when I'm using the GPS, so that's okay. [The phone can draw 1.2 Amps if I modify a 2 Amp charger.])
    05-27-2015 06:53 PM
  1. Why are my devices not discovering or pairing with my Pill?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 05-29-2015, 01:18 PM
  2. How can I get back the app drawer from solo launcher?
    By bhatta in forum Android 5.0 Lollipop
    Last Post: 05-27-2015, 10:07 PM
  3. why does my gallery not have my album even tho its on sd card
    Last Post: 05-27-2015, 06:56 PM
  4. I cannot connect to the Internet
    Last Post: 05-27-2015, 01:11 PM
  5. Replies: 0
    Last Post: 05-27-2015, 01:07 PM
