1. AC Question's Avatar
    I've enabled Smart Lock and see the option but can't select it, it's grayed out. I did see the feature a few days ago and recollect setting it up to smart lock including the on body detection. Anybody know why it is disabled? Is some other setting of mine interfering perhaps? I unlock using fingerprints and have an Exchange account setup.
    05-31-2015 03:47 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to Settings>Security>Trust Agents​, and make sure Smart Lock is turned on there.
    06-01-2015 02:20 AM
  3. vatsan's Avatar
    Smart Lock (Google) is turned on under Trusted Agents. Without that I won't even see the option under Secure lock settings.
    What else?
    06-01-2015 10:04 PM
  4. B. Diddy's Avatar
    Hmm. Do you use the phone for work, and if so, do they require any kind of security on the phone short of encryption? Security policies might prevent you from using certain unlock features. You could try going to Settings>Security>Clear Credentials, although that might affect any security that is required for your work.
    06-02-2015 01:59 AM
  5. Roberto4's Avatar
    Go to settings -> security -> device administrators and then (temporarily) turn off apps such as Outlook / Exchange. These apps can restrict some options like smart lock.
    Once you've disabled the phone admin apps which are restricting, you'll be able to adjust smart lock settings. After changing the settings, turn the device admins back on, or else in this case you might not be able to use outlook anymore.
    I know this post is old, but I just figured it out and it might help others searching through the forums for help.
    01-04-2016 06:20 PM
  1. Replies: 1
    Last Post: 06-01-2015, 02:27 AM
  2. Text on Samsung Galaxy 3 is very large how to change
    Last Post: 06-01-2015, 02:24 AM
  3. how do i root my samsung galaxy fame
    Last Post: 05-31-2015, 10:47 PM
  4. Where can I find free ringtones for Galaxy S6?
    Last Post: 05-31-2015, 10:44 PM
  5. Verizon S6 Edge Question
    By kizilat in forum Samsung Galaxy S6 edge
    Last Post: 05-31-2015, 03:38 PM
