1. Shirley Goh's Avatar
    Samsung Tab 2 7.0... battery charing is fine, but the phone keep rebooting after start up within a min.. but there is few time i saw a message something like... google.process... stop then it auto reboot again. I still able to shut down the phone if it do it before it auto reboot.
    Please help, i need to save my data out. thanks.
    06-01-2015 05:00 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! First, try wiping the cache partition, which won't erase any personal data: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2..
    If the problem persists, then try booting into Safe Mode, which temporarily disables all 3rd party apps. https://support.t-mobile.com/docs/DOC-18895
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    06-01-2015 01:10 PM
  3. Shirley Goh's Avatar
    Hi..Thanks for the reply.
    I charged the battery up to 100% with the phone off, then follow the GUIDE you provide, but the system stop there when the logo appear..even I tried to off it it still reboot till the logo appear and stop there. I even try to press the Start and volumn down button, there is a screen with downloading words but it still stop there... So I have no choice to send my phone to repair shop.. I m not sure what the technician guys did to the phone but they did open up the case...at the end they told me is the hardware problem and now it totally cannot start up...black out...
    06-03-2015 09:48 AM
  4. B. Diddy's Avatar
    It sounds like what you were initially experiencing was all symptomatic of the impending hardware failure. Are you going to get it repaired, or just get a new device? The Tab 2 is pretty old, so paying to repair it might not be worth it--especially since you can get a Tab 4 for around $120 these days.
    06-03-2015 10:54 AM
  1. Why does my Galaxy Tab 2 keep recycling back to home screen?
    By AC Question in forum Samsung Galaxy Tab 2
    Last Post: 06-02-2015, 01:52 AM
  2. Replies: 1
    Last Post: 06-01-2015, 01:14 PM
  3. Replies: 1
    Last Post: 06-01-2015, 01:12 PM
  4. Replies: 1
    Last Post: 06-01-2015, 06:20 AM
