1. Thromper1984's Avatar
    I have a Moto E, I charged it overnight and it has been three hours. My battery is still completely full, although it really shouldn't be. I think the indicator has a glitch of some sort. Any advice on how to fix it?
    06-03-2015 12:37 PM
  2. anon8380037's Avatar
    Hello.
    I would stick that on Shop Android or eBay and make your fortune.
    Try the GSam app in the meantime and see if it displays the battery percentage correctly. It also allows you to put it's own percentage indicator on the notification bar.
    You could try toggling on and off the device battery indicator if it has one.
    How does the Battery Usage graph look?
    You can touch the graph to get more information.
    06-03-2015 01:20 PM
  1. My tablet is stuck in an unlock bootloader mode, how can I get out of this?
    By caballerolance in forum Google Nexus 7 Tablet (2013)
    Last Post: 10-26-2016, 10:44 AM
  2. LG G4 Battery Life Thread
    By chobits in forum LG G4
    Last Post: 04-13-2016, 11:10 AM
  3. How do I stop cell standby from draining my battery?
    By AzureFDemon in forum Samsung Galaxy S6 edge
    Last Post: 12-02-2015, 04:49 PM
  4. Restore HTC One M8 Back to 100% stock help.
    By Josh Douch in forum General Help and How To
    Last Post: 07-10-2015, 02:40 PM
  5. S4 Bootloop(Wont turn)Unless Battery removal then turns off in 2 seconds
    By Menkotucky in forum General Help and How To
    Last Post: 06-27-2015, 02:20 AM
