1. AC Question's Avatar
    In the past day my Samsung S5 has been overheating and my battery is draining super fast. I also cannot reconnect to wifi now-what is going ?
    John G
    06-04-2015 05:23 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It sounds like the first thing to do is figure out why it's overheating and the battery is draining. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    A corrupt file on the SD card is a common cause of overheating and battery drain, since it can cause the system's Media Scanner to get stuck on the file, which leads to excess CPU usage and battery drain. Unmount the SD card (in Settings>Storage), remove it, and reboot. You can also put the card in your computer and run chkdsk to look for bad sectors. [GUIDE] Using chkdsk to fix a corrupted SD card
    Another possibility is a failing or defective battery--try a different one.
    What exactly happens when you try to turn on wi-fi? Does it turn on, but just not connect? Or does it turn on, then turn off by itself? Or are you not even able to flip the switch on?
    06-04-2015 11:51 AM
  1. Replies: 1
    Last Post: 06-04-2015, 12:18 PM
  2. Why am I not able to view photos without internet?
    By Jeev Varghese in forum Google Nexus 5
    Last Post: 06-04-2015, 12:16 PM
  3. not enough memory delete some items
    Last Post: 06-04-2015, 12:09 PM
  4. Replies: 1
    Last Post: 06-04-2015, 04:20 AM
