1. AC Question's Avatar
    I have been reading most of the thread but a little confused. I have a note 3 with unlimited data. I want to upgrade to the note 4. Does the best buy method still work? I know at one point in the check out it gave the option to keep existing plan but now the option is no longer there and says will be changed to 2gb of data. If i upgrade do I still just order from best buy choose ship to home then place in old sim card and let ti activate itself still?
    06-04-2015 12:54 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Have you looked over this thread: http://forums.androidcentral.com/ver...ml#post4293937
    06-06-2015 08:21 AM
  1. may i have step by step directions on rooting galaxy tab3?
    By Venustrap in forum Samsung Galaxy Tab 3 Rooting, ROMs, & Hacks
    Last Post: 11-02-2015, 02:30 PM
  2. Why am I unable to download as pps?
    Last Post: 06-09-2015, 11:31 AM
  3. How can I use the keypad during a handsfree call?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 06-09-2015, 11:28 AM
  4. Replies: 4
    Last Post: 06-07-2015, 01:53 AM
  5. How do I Block a incoming call on my Android Z998 smart phone
    Last Post: 06-06-2015, 12:42 AM
