1. AC Question's Avatar
    So this is weird, when my phone is off it wont detect the charger, when its on it wont detect charger. To begin with when the phone died, I just got a battery icon within the lightening bolt, if I tried to turn it on, I got the whole optimising apps 1 of 150, which would then go black and i'd get a red flashing notification light.
    I googled a little and found a possible solution of using the bootloader screen to try and boot it, I noticed while doing this it was actually charging when in this screen. I left it on this screen for about an hour, and tried booting the phone.
    It got through all 150 of the optimising apps and booted up! My batter showed around 3% left, but wasn't charging. I have now shut it down and am charging it more.
    Any suggestions? it's clearly not the micro SD port or the charger that is broke...
    06-08-2015 06:12 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! If the battery is severely depleted (which you should always avoid if at all possible), then you might have to leave it on a wall outlet undisturbed for at least 4 hours or so before the battery has enough power to complete the boot process.
    mrsmumbles likes this.
    06-08-2015 11:45 AM
  1. Replies: 6
    Last Post: 07-28-2015, 10:15 PM
  2. Lollipop Battery Life Was Good, Now Terrible.
    By music_man185 in forum Verizon Samsung Galaxy Note 3
    Last Post: 07-22-2015, 09:50 AM
  3. Replies: 34
    Last Post: 06-10-2015, 09:12 AM
  4. Why wont my phone allow apps to install?
    By Drongo79 in forum Android Apps
    Last Post: 06-08-2015, 05:53 AM
