11-02-2016 01:43 AM
27 12
tools Reply
  1. kunapareddy avinash's Avatar
    Hi Friends,
    You can remove vibration feedback after answering call in android mobiles without rooting by following the below easy steps.
    1. download mtk engineering app from play store.
    2 . open mtk engineering app and go to mtk settings there you will find Misc Feature Config option.
    3. after entering into the above mentioned option you will find Vibrate on outgoing call connected option, deselect that option.
    That's it, you will be free from vibration feedback after answering the call.
    Note : This works only for media tek processor mobiles.
    10-26-2016 07:36 AM
  2. MarcinWasilewski's Avatar
    Best answer ever. Thanks
    11-02-2016 01:43 AM
27 12
  1. How to get quick charge on lg g4?
    By Throwbackent in forum LG G4
    Last Post: 10-04-2015, 09:14 AM
  2. Will the Galaxy Mega update to Lollipop?
    By AC Question in forum Samsung Galaxy Mega 6.3
    Last Post: 07-15-2015, 05:11 PM
  3. How to get rid of "other contacts" from Gmail
    By ArtieTheOneManParty in forum LG G3
    Last Post: 06-09-2015, 01:44 PM
  4. Why won't my wifi connect?
    Last Post: 06-08-2015, 08:06 PM
