1. AC Question's Avatar
    callers hear a beeping when i am getting incoming calls
    06-09-2015 08:59 PM
  2. Almeuit's Avatar
    I don't think you can since the beep is coming from your phone company. You can disable the pop-up on your phone under settings, then more settings within the app -- but I don't know if that will stop the beep.
    06-10-2015 02:35 PM
  3. cwolfey's Avatar
    If your referring to the beep people hear when your on the phone, I noticed that it doesn't do that if you have Volte Advanced Calling enabled.
    I actually like that feature and am disappointed that it doesn't work while the advanced calling is active.
    This is for Verizon.
    06-10-2015 02:48 PM
  1. Replies: 16
    Last Post: 03-09-2017, 12:46 AM
  2. How can I get 5.1 to show the battery percent on the top bar?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 08-20-2016, 01:22 AM
  3. Why won't my GoSMS links open in Chrome??
    By Marquyse Jackson in forum Ask a Question
    Last Post: 06-10-2015, 07:39 PM
  4. Replies: 1
    Last Post: 06-10-2015, 07:37 PM
  5. Replies: 1
    Last Post: 06-10-2015, 06:10 AM
