A
AC Question
When I'm at work, my battery drains really fast. When I press and hold the home button, which brings up the tasks, the task running simply says "phone", when I'm not using the phone, nor have used it in some time. I'll kill the task, only for it to be there again, usually within 10 minutes. I work next door to a phone company, which has towers on the side of their building. The only time this "phone" task is running like this is when I'm at work. It does not have this task running normally. The only solution I've come up with thus far is just shutting the phone off while I'm at work, as there's no electrical outlet available for me to charge, and I hate using my car charger. Ive read other threads which gave instructions to change global network settings, etc. I've done all of that. No luck.
