1. AC Question's Avatar
    I'm using panasoniC Eluga S mobile and at tHe beginig of tHe puCHase it was working well
    and later proximity sensor was not working
    wHere an i find proximity sensor setting in it????
    06-14-2015 10:13 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Try getting a can of compressed air and lightly spray the earpiece of the phone. There could be some dust in the case that is causing an issue. Be sure not to spray directly or too close to the earpiece so you don't damage it.
    06-17-2015 09:09 AM
  1. Replies: 12
    Last Post: 07-14-2015, 09:28 AM
  2. Galaxy Note 3 Used to Work on MHL Cable, But Not Any More. Why?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 06-16-2015, 12:59 PM
  3. Replies: 1
    Last Post: 06-16-2015, 12:56 PM
  4. Galaxy V Custom ROM problem
    By ilikeKayle in forum Ask a Question
    Last Post: 06-14-2015, 07:38 AM
  5. problem with android os using mobile internet in background
    Last Post: 06-14-2015, 06:48 AM
