1. LGExceed 223's Avatar
    My LG Exceed 2 has an x over the battery and stays "Not Charging, ease connect original charger" but the thing is, I'm using the original charger.
    06-14-2015 09:26 PM
  2. Rukbat's Avatar
    You'll have to try a known good charger to determine if it's a bad charger, or a bad phone or battery. If it's not the charger, you'll need a known good battery to determine if it's a bad battery or a problem in the phone.
    06-14-2015 09:29 PM
  1. How to divert an incoming call to voicemail (not ALL calls)
    By Pterocarpous in forum Samsung Galaxy Note 4
    Last Post: 06-15-2015, 10:03 AM
  2. Replies: 1
    Last Post: 06-15-2015, 01:03 AM
  3. General notification sound will not change...
    Last Post: 06-15-2015, 01:01 AM
  4. Replies: 3
    Last Post: 06-14-2015, 09:42 PM
