1. AC Question's Avatar
    I have just install Hide It Pro on my Samsung Android cell phone but need to print the help file to be better able to read and learn to use the App properly.
    06-15-2015 03:11 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If it isn't a text file or a document that can be opened in something like Google Docs, then it'll be very tedious, because you'll probably have to take a screenshot of each page and then print each screenshot.
    The app page has a link for a help document, but it's a broken link. Their website also isn't that helpful. You may want to email their support team and request the help documentation in a single file that you can then print out: support@hideitpro.com
    06-15-2015 03:21 PM
  1. supersu how it works?
    By Sally Delyth in forum Ask a Question
    Last Post: 06-29-2015, 08:24 PM
  2. Hello Android Central People!
    By MadMonkey119 in forum Introductions
    Last Post: 06-28-2015, 01:52 AM
  3. Replies: 1
    Last Post: 06-18-2015, 08:19 AM
  4. Can I get some general direction for my first root?
    Last Post: 06-15-2015, 04:32 PM
