1. AC Question's Avatar
    Do I need a special usb cord to use mirror link in my car
    06-15-2015 05:06 PM
  2. itguyjax8430's Avatar
    This is from one of the MirrorLink distributors websites. So it looks like it depends on what kind of phone you have.
    MirrorLink is designed to provide easy-to-use in-dash control over compatible smartphones. The system needs three elements to do its thing: a compatible in-dash receiver, a compatible smartphone, and an app that works with MirrorLink. The system works like this:
    Download the app (prices vary) to your compatible phone. Launching the app provides a simplified graphical interface that’s ideal for use in the car, because it's easy to see at a glance, and much easier to use.
    Connect your phone to the receiver. This can sometimes require a special cable or interface.
    Launch the app on your phone, and tap the MirrorLink icon in the receiver’s source menu. The optimized carmode menu will appear on your receiver’s screen.
    06-18-2015 08:29 AM
  1. Dropbox on my note 4
    By Krack-Berri in forum Samsung Galaxy Note 4
    Last Post: 08-30-2015, 06:12 PM
  2. User Interface error in Chaos Rings 3 on Samsung Galaxy S4
    By Shiranui45 in forum The Gamer's Lounge
    Last Post: 07-12-2015, 08:14 PM
  3. Cheap-ish phone with USB OTG support?
    By flashbot in forum Ask a Question
    Last Post: 06-16-2015, 06:22 AM
  4. Replies: 1
    Last Post: 06-15-2015, 05:14 PM
  5. how to set up micro sd card?
    By David Anderson13 in forum Samsung Galaxy S3 Mini
    Last Post: 06-15-2015, 04:59 PM
