1. AC Question's Avatar
    I have an LG G3 (lollipop 5.0.1) and whenever I clear all of the recent apps that I used and tap on the recent apps button again (the square button on the navigation bar of the lollipop os), the message "unfortunately, system UI has stopped working" pops out. I factory reset my phone three days ago because the same message kept on popping a week ago so I figured resetting it would do the trick, but yeah, apparently not.
    06-15-2015 05:43 PM
  2. Winston P's Avatar
    Have you installed anything since then? Try resetting the phone through the recovery menu. If the problem persists, I'd recommend flashing a new ROM onto the device, or just take it to LG to get them to do it for you.
    06-16-2015 08:08 AM
  1. Replies: 9
    Last Post: 04-18-2016, 01:41 PM
  2. Replies: 2
    Last Post: 09-15-2015, 03:12 PM
  3. How do I transfer photo's from my S4 to my home computer?
    Last Post: 06-18-2015, 08:31 AM
  4. How to get partial update apl from play store on android one?
    Last Post: 06-17-2015, 04:54 PM
  5. Remove Microsoft Exchange Account for my Galaxy
    Last Post: 06-16-2015, 08:09 AM
