1. AC Question's Avatar
    ok, I hope I can make sense of this for you to help me? My wife has an S5 mini and I have the S5 and we often have to make calls where by she will leave the phone on the side and not have it to her ear. More often than not I am unable to hear all of her speaking and the quality is very intermittent. The phone signal can be fine and we have no idea what causes this issue. Would it be a microphone issue as it becomes more audible the louder she speaks or sounds or the signal itself? When the phone is to her ear there is no issue at all. Either way any help you can give me would be much appreciated or any settings that we can change or tests we can run?
    Thank you
    Gary
    06-16-2015 04:18 PM
  2. itguyjax8430's Avatar
    Thank you
    Gary
    Welcome to Android Central!
    It could be the noise reduction feature working, since she is getting further way from the phone it is thinking that she is background noise. Try going into dialer, go to the settings in the dialer, go to call, and un-check Noise Reduction. See if that helps.
    06-19-2015 07:47 AM
  1. Replies: 2
    Last Post: 09-18-2015, 08:44 PM
  2. Hot Spot / Phone Call Issue - VZW G4
    By lordgoofy in forum LG G4
    Last Post: 08-06-2015, 06:01 AM
  3. I have unrooted my phone, but it refuse to update. What should I do?
    Last Post: 06-19-2015, 07:41 AM
  4. Replies: 1
    Last Post: 06-19-2015, 07:37 AM
  5. How do you download themes from the S6 Theme Store?
    Last Post: 06-16-2015, 04:08 PM
