1. Stephy's Avatar
    I just got my LG G3 last week and upgraded to Lolipop. My battery drains so fast. I understand it's a large screen and that takes a lot of battery, but the scteen is usually at 65-70% of the battery usage, which I feel is high. I have been keeping it at 30% brightness. The other apps are at 7% and below on usage. I was watching it go down 1% every two minutes today. Did a factory reset and doesn't seem to be helping. Did I get a lemon or is this the life of the G3?
    06-16-2015 10:48 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If the screen is on non-stop, then it wouldn't be surprising that it uses that much battery. The important question is how much screen-on time you get with one charge.
    06-17-2015 02:17 AM
  1. Battery Tip - force to 3g?
    By berdinkerdickle in forum Samsung Galaxy S6
    Last Post: 06-20-2015, 04:20 AM
  2. Why is Kik suddenly using most of my battery life?
    By AC Question in forum Batteries
    Last Post: 06-19-2015, 08:57 AM
  3. Replies: 1
    Last Post: 06-19-2015, 08:48 AM
  4. Replies: 1
    Last Post: 06-19-2015, 08:45 AM
  5. Replies: 1
    Last Post: 06-17-2015, 02:34 AM
