1. AC Question's Avatar
    I updated my s6 edge to 5.1.1 yesterday and it started overheating for no reason, and the battery dropped from 100% to 84% in 10-15 minutes with no apps running. Before this its battery life was great and there was no overheating issue. What do I do?
    06-17-2015 09:32 AM
  2. belodion's Avatar
    Welcome to AC.
    In the first instance, try a Cache Partition wipe, which is easily done and which causes no loss of personal data.
    If that doesn't fix it, get back to us.
    06-17-2015 02:49 PM
  3. nicks6's Avatar
    I wiped the cache partition and the problem is not as bad-phone still gets a little warm, and hotter than normal with moderate use, and the battery life is much better, but not as good as pre-update state.
    06-18-2015 02:47 PM
  1. Replies: 3
    Last Post: 06-17-2015, 01:12 PM
  2. My samsung galaxy s5 restarted and sending sms continuously
    Last Post: 06-17-2015, 09:27 AM
  3. Why am I not able to transfer photos from Samsung S6 Edge to my Macbook?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 06-17-2015, 09:26 AM
  4. Why does my Hot Spot turn OFF on its own?
    Last Post: 06-17-2015, 09:22 AM
  5. my phone network is hacked.
    By Louise edmonds in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 06-17-2015, 09:21 AM
