1. CellTheUltimateAndroid's Avatar
    isn't it ironic that an app that monitors battery works in the background and eats battery??!
    06-17-2015 03:18 PM
  2. anon8380037's Avatar
    GSam has been one of the few great unobtrusive apps for me.
    If you can post a screenshot of your Battery usage, you can get more specific advice.
    I take it App Analyser is specific to the LG and your G3, I am not familiar with it.
    I don't see from your shot where it's using battery, just data.
    GSam barely registers at all on my Motorola or Samsung Battery usage.
    You asked the same question on the G3 forum and it's not great to compete with similar responses elsewhere.
    06-17-2015 03:33 PM
  1. Battery Drain Question
    By FroggyStyle in forum Samsung Galaxy S6 edge
    Last Post: 06-18-2015, 07:30 AM
  2. Samsung Galaxy battery
    By ElBokhari in forum Samsung Galaxy S5
    Last Post: 06-17-2015, 09:48 PM
  3. Where can I find a case for the battery?
    By dpham00 in forum LG G4
    Last Post: 06-17-2015, 03:59 PM
  4. Do quick chargers kill battery life?
    By erwaso in forum LG G4
    Last Post: 06-17-2015, 01:52 PM
  5. Use Net 10 sim card on Cricket device?
    By faith3935 in forum Ask a Question
    Last Post: 06-17-2015, 12:03 PM
