1. AC Question's Avatar
    Not completely but partially, it will not turn off, but it will turn on and with the power off menu. When i can turn it off ( rarely ) it is delayed and turns off quickly then right back on. Before you ask, i did try the reset, even factory reset, im thinking it is some update to something but i have no idea i do know that it started when i tried to take a screenshot. It is a Droid Razr M XT907, if anyone can help that would be amazing thanks.
    06-18-2015 06:42 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The power button itself might have become damaged when you were pressing it for the screenshot. Something like that would have to be looked at by a technician, unless you're really good at taking phones apart and replacing parts.
    06-19-2015 01:03 AM
  1. HTCBackup is not working....
    Last Post: 06-19-2015, 05:10 PM
  2. Replies: 5
    Last Post: 06-19-2015, 02:41 AM
  3. What part of my cell is broken and can I fix it?
    Last Post: 06-19-2015, 01:14 AM
  4. Replies: 1
    Last Post: 06-19-2015, 01:07 AM
  5. Static/ pop noise coming from my battery or speaker?
    By carlyr97 in forum Ask a Question
    Last Post: 06-18-2015, 06:33 PM
