Note 4 - Lollipop 5.0.1 - TouchWiz doesn't retain 'ALWAYS' setting
A
AC Question
Hi there
I have a Note 4 and finally have been able to update to 5.0.1. Ever since, apps will semi-frequently (not every occasion) forget that I set TouchWiz as my standard app when pressing the home key.
I might be using Facebook through the day, and 5 out of 10 times will get the sliding pop-up asking which app to set. I choose 'always' each time.
It has happened to a few apps - messaging apps, Facebook, my non-native text app as well as some native apps like phone or even settings.
To try and correct this, I restarted my device. The issue persisted so I have cleared the cache and pressed 'always' on Facebook the next time I got the pop-up.
I am reluctant to do a factory reset or any other drastic tests.
Any ideas?
itguyjax8430
Retired Moderator
Mar 15, 2013
6,822
Hi there
Any ideas?
Welcome to Android Central!
I hate to say it but doing a factory reset will more than likely fix all your issues. I did one as soon as I received the update and have had 0 issues.
ThatDude
