1. Neil James's Avatar
    Hi. I'm new to this forum and still trying to find my way around. I have been looking for advice on how to root my device but have not been able to find any advice on here as yet.
    I'm not very tech savvy, but have seen advice to try Towelroot (doesn't work).
    My tablet is one of those cheap budget ones - Allwinner A31. It's Kitkat 4.4.2, Quad Core, 1.2 Ghz, build date is May 2014.
    The big problem I have is that although it was advertised as 6GB internal memory, it's partitioned to a 1GB/4.5GB split with apps downloading onto the smaller section which also has the bloatware on. Ideally I would like to remove the partition to give me a larger internal memory.
    I have a 32GB SD card installed which allows me to move some apps and other storage (pics/music/books etc) but obviously not all apps.
    So: I need to either remove the partition or root the device.
    Any advice would be greatly appreciated.
    thanks in advance.
    06-19-2015 07:27 AM
  2. itguyjax8430's Avatar
    thanks in advance.
    Welcome to Android Central!
    Have you tried using FramaRoot?
    06-22-2015 07:41 AM
  3. Mohamed Boud's Avatar
    I got the same problem
    08-20-2015 03:21 PM
  1. New S6 owner - need advice please
    By treble0 in forum Samsung Galaxy S6
    Last Post: 06-20-2015, 10:34 PM
  2. Help to anyone without heating issues
    By TechGod2014 in forum LG G4
    Last Post: 06-20-2015, 03:28 PM
