1. AC Question's Avatar
    The battery indicator and percentage show that I have a lot of battery left like 75% for example, but it doesn't go down after constant use and the it just turns off, because the battery is dead. Any ideas how to fix this issue?
    06-19-2015 10:45 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    You should give GSam Battery Monitor a try. It is one of the best out there
    https://play.google.com/store/apps/d...m.gsamlabs.bbm
    06-21-2015 07:49 PM
  1. Battery life after 5.1 update
    By donebrasko in forum Moto 360
    Last Post: 07-24-2015, 12:31 PM
  2. Replies: 1
    Last Post: 06-22-2015, 12:36 PM
  3. Google Services = Battery Drain Services
    By Inders99 in forum LG G4
    Last Post: 06-20-2015, 12:01 PM
  4. Replies: 1
    Last Post: 06-20-2015, 06:08 AM
  5. Gsam Battery Monitor
    By razza1987 in forum Samsung Galaxy S6
    Last Post: 06-19-2015, 10:35 PM
