1. Steven Sciple's Avatar
    I have to help a friend get a new Verizon smartphone. He is not very tech savvy, but wants an up to date smartphone. He currently has droid razr m. I'm looking at either s6, droid turbo, g4, or note 4. I'll spend the next year explaining everything but with the note 4 the same price as the s6 of g4 am wondering if I should learn that way.
    06-20-2015 05:31 AM
  2. belodion's Avatar
    Not very tech-savvy? Those are all high-end devices!
    What features are important to your friend in a phone, apart from being up-to-date and, presumably, simple to understand and use?
    06-20-2015 05:39 AM
  3. Steven Sciple's Avatar
    He "has to have the best" but most features will not be used. Basically uses the alarm, phone, gmail, and text messaging. I am going to try to teach him to use it more, but it will take time.
    06-20-2015 05:52 AM
  4. aximtreo's Avatar
    You have your hands full in my opinion.
    I would recommend that you take him with you to the Verizon store and let him hold and use each of the models you mentioned. I personally use the Note 4 bu the large size doesn't hinder my needs.
    He may even see a lesser phone he likes better. This is a large investment of his money and your time so be as thorough as you can in helping him decide on which one he likes.
    Lastly, Good Luck.
    06-20-2015 09:51 AM
  1. Will others see my backdrop pic set up for my CHROMECAST?
    By AC Question in forum Google Chromecast
    Last Post: 07-10-2015, 02:46 AM
  2. Replies: 4
    Last Post: 06-30-2015, 11:30 AM
  3. i need help !!!!!!!!!!!
    By PKSTAK in forum General Help and How To
    Last Post: 06-28-2015, 01:55 AM
  4. Play Netflix on vizio TV from Android phone
    Last Post: 06-20-2015, 06:41 PM
  5. i need help !!!!!!!!!!!
    Last Post: 06-20-2015, 07:59 AM
