my phone into water
A
AC Question
my galaxy tab fell into water while i was on for like 10 seconds i wasn't totally submerged but it was on went i pick it up the screen was kind of fuzzy but worked then i switched off then sucked the water out with my mouth. thenthis morning tried truning it on it i display an android teddy say downloading then i switched it off again there was trouble trying to switch it one but now it just blank don't know what to do
the tall guy
Q&A Team
Sep 23, 2013
7,210
sucking the water out with your mouth wasn't the best option, but it was creative :) stick the tablet in a big bag of rice and leave it for a couple of days, maybe the rice will dry out whatever moisture is left in the device. If that doesn't work it might be worth while contacting Samsung to arrange a quote to fix the tablet. There isn't really anyway to fix it yourself.
