1. AC Question's Avatar
    So the device I have is a android based projector called Odin by DosOwls. The Wifi connectivity is very weak. I have tried everything with my end with my network to boost it as much as a I can but it still is still very slow. After doing some digging in the android settings I found a ethernet feature in the OS. I bought a USB to ethernet device which works very well but I want a wirless solution. I tried using a wifi dongle but it doesn't work or not sure if its even compatabile. Is there a device I can use to basically give my device a new wifi chip.
    07-01-2015 01:30 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is it the same on any wi-fi network, or have you only tried it on one network?
    07-01-2015 10:41 PM
  1. Replies: 2
    Last Post: 10-15-2015, 04:48 AM
  2. Need some suggestions
    By Hasibuzzaman Tonmoy in forum General News & Discussion
    Last Post: 07-03-2015, 04:02 AM
  3. What is wrong with my gmail app?
    Last Post: 07-01-2015, 10:49 PM
  4. Replies: 0
    Last Post: 07-01-2015, 12:39 PM
  5. Replies: 1
    Last Post: 07-01-2015, 11:11 AM
