1. AC Question's Avatar
    I have a samsung rugby pro which is 2 1/2 years old. It worked fine until about (1) month ago. Now my battery drains extremely fast. I replaced the battery but my display says my home screen is using 57% of my battery. I had a moving home screen which at&t advised I remove. This dropped the screen usage from 58% to 57%. Anybody have any other idea what I can do to solve screen battery usage? I do not know what operating system is in my phone.
    07-01-2015 08:04 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The main question here is how much total screen-on time you're getting per charge. If you're using the phone constantly and the screen is always on, it will definitely be the biggest battery consumer, and the battery level will go down relatively quickly.
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    07-01-2015 09:49 PM
  1. Default HSPA setting on Samsung Galaxy S6 on Tmobile US
    Last Post: 07-09-2015, 01:36 PM
  2. How can I fix my Android, it turns on my data and wifi every time I lock the screen?
    By confusion645 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-03-2015, 11:54 PM
  3. Is there a way to change my notifications back before the new update?
    By Raex1 in forum General News & Discussion
    Last Post: 07-01-2015, 08:09 PM
  4. How ca i disable flipbnoard on notes 2
    Last Post: 07-01-2015, 08:05 PM
  5. Why are my Driod smiley emoticons distorted on my Galaxy S3?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 07-01-2015, 07:47 PM
