Hello. Do you have a removable battery so you can check for a bulge, or try another. What device. Have you tried charging with a different cable or from a pc usb.
Do you get any visual activity at all?
It's probably either the battery, cable or device connectors. Can you get a store or independent repair shop to look at it?
