1. bundroid's Avatar
    Ive got a Samsung Galaxy Note edge, and had information streaming on the edge screen like news and shares in normal use. The edge screen doesnt stream anymore! Has anyone got this problem? I dont know if the lollipop update had ote to do with it but that update was the worst thing ever! No point having an edge screen when the major features gone, theres a lack of apps for the edge screen as it is.
    07-05-2015 07:15 PM
  2. Jowlah's Avatar
    Did you go into the Edge Screen options? On the Edge screen, swipe the bottom of the screen up until you see the gear icon. Tap that, then go into Information Stream and make sure it's on.
    07-25-2015 08:03 AM
  1. samsung galaxy s5 wake up problem
    By Kundai Maurede in forum Ask a Question
    Last Post: 10-30-2016, 11:46 PM
  2. How you change your username on the game "Uno"?
    Last Post: 07-05-2015, 07:12 PM
  3. Replies: 0
    Last Post: 07-05-2015, 07:02 PM
  4. Replies: 0
    Last Post: 07-05-2015, 06:59 PM
  5. Replies: 0
    Last Post: 07-05-2015, 06:58 PM
