1. maiameister's Avatar
    I am a Samsung Galaxy S4 user, and I have an issue.
    A year after I got my phone, I've noticed that my battery life started to shorten. A few months later, my phone started to die at 15%.
    I got my phone's battery replaced for free. The broken battery was swelled up. I was shocked.
    But after a while, the new battery started to shorten again. Is this normal?
    I don't know if I'm just unlucky to have 2 faulty batteries, or I'm not supposed to use my phone while charging, or what. I've tried multiple battery apps, but none of them worked.
    I read the manual again, and it says that I could use my phone while it charges. So what's the problem?
    I don't know if I just have too many background apps (which I try to maintain to a minimal) or it's just my data.
    Currently, I lose 1% every few minutes. Please help.
    07-09-2015 01:28 AM
  2. maiameister's Avatar
    Someone help me, pleeeaaase.
    07-09-2015 03:12 AM
  3. FiveOverEight's Avatar
    Mine started doing the same thing after about 18 months. What I did was purchase an Anker battery that is double the capacity of the S4 one as standard.
    I assume like mine, that yours is possibly reaching it's end of life as nothing I did improved battery life.
    07-09-2015 04:28 AM
  4. maiameister's Avatar
    How much is this "Anker" battery? And is it worth it?
    07-09-2015 04:36 AM
  5. FiveOverEight's Avatar
    Mine was £20 from Amazon.
    07-09-2015 11:05 AM
  6. Paul K2's Avatar
    I have a similar problem with my S4. I found out quite by accident that if I let my battery run completely out and shut down the phone that when I recharge it it holds the charge longer. When it starts to lose charge quicker I just let it run completely down till shut off then start again. I have done it to my wife's S4 also.
    07-09-2015 11:36 AM
  7. Tom Demey's Avatar
    Turn down your brightness, shut down your wifi, clear your running apps. Have you done this?
    07-09-2015 01:10 PM
  8. maiameister's Avatar
    Yes, I have.
    07-09-2015 11:26 PM
  9. souvikultimate's Avatar
    It is very normal problem for S4. Try battery doctor app.
    07-09-2015 11:34 PM
  10. maiameister's Avatar
    I have, actually. But it doesn't work at all! It's says my phone has six hours, and then a percent went down then it says 5 hours.
    07-10-2015 12:42 AM
  11. Butterscotch43's Avatar
    07-10-2015 01:44 AM
  12. Butterscotch43's Avatar
    I had the same problem. And I u the apps didn't help . I just ended up getting the galaxy 5. But now my phone gets hot .
    07-10-2015 01:45 AM
  1. Why won't my Samsung Galaxy Tab 3 turn on/charge?
    By TheBronyArtist12 in forum Samsung Galaxy Tab 3
    Last Post: 07-12-2015, 02:14 PM
  2. Can't login to Google Photos from new Samsung Galaxy S6
    Last Post: 07-11-2015, 11:54 AM
  3. Can I get some help removing my OS?
    By Ritchey Canada in forum Samsung Galaxy Note 4
    Last Post: 07-09-2015, 02:33 AM
  4. Why can't I make a conference call on my Samsung Note 3 phone?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 07-08-2015, 10:56 PM
