1. AC Question's Avatar
    Hi everyone,
    I dropped and broke the glass of my Nexus 5 (D821 European model) and I ordered a front panel replacement. I did the replacement as I saw on some youtube videos and the screen is working fine now. The problem is that the position of the touch is way wrong. If I touch the screen on the upper right corner I get a "click" on the middle right and if I touch the screen on the low right I get a click just on top of the middle right.
    So it seems that the touch is mis-interpreted by half screen!
    Have you seen / heard something similar ?
    Can this be caused due to a mistake I did in the process of reassembling the phone ?
    Can this be because the part is from a D820 (U.S model) ?
    Many thanks in advance!
    Your help is appreciated!
    07-11-2015 02:36 PM
  2. Carlos Cuamatzin's Avatar
    Having the same issue, did you find a solution?
    08-31-2015 01:26 PM
  1. Why is my LG4 heading up and the screen dimming?
    Last Post: 08-21-2015, 08:04 PM
  2. Copy screen to text box after paste screen swipe
    By Marioclement23 in forum Samsung Galaxy S5
    Last Post: 07-13-2015, 06:34 AM
  3. My Nexus 5 won't switch on
    By suhasrrao in forum Google Nexus 5
    Last Post: 07-11-2015, 04:11 PM
  4. How do I turn off the notification .like message that appears on screen?
    Last Post: 07-11-2015, 01:29 PM
  5. Replies: 0
    Last Post: 07-11-2015, 12:31 PM
