1. AC Question's Avatar
    The screen is black but the bottom buttons light up ...I shined a flashlight in it and don't see anything. Can you please help me ??
    07-12-2015 11:19 PM
  2. srkmagnus's Avatar
    There appears to be problems with the LCD panel, which needs to be replaced. You can try taking apart the device and make sure that all the connections are intact...but the problem likely is the panel itself which will need to be replaced.
    07-13-2015 12:04 AM
  3. Darryl Ware's Avatar
    You can see the lock screen sometimes... I'm scared to take apart because I don't wanna mess it up more and also I have no idea what I'm even looking for
    07-13-2015 12:30 AM
  4. srkmagnus's Avatar
    Welcome to the forums!
    There are many how-to videos on the internet that will show you the process. Still, it's a very delicate process and can be easily damaged if you don't take it apart properly. I wouldn't suggest replacing it on your own if you can send it for repair.
    07-13-2015 10:08 AM
  1. Replies: 1
    Last Post: 07-13-2015, 06:25 AM
  2. How do I switch browsers?
    By Tw20n17 in forum General Help and How To
    Last Post: 07-13-2015, 01:41 AM
  3. can't send images through my messages
    By RexSergivs in forum Ask a Question
    Last Post: 07-13-2015, 12:03 AM
  4. How can I make contacts use FB profile pics over Linkedin pics?
    Last Post: 07-12-2015, 11:16 PM
  5. Replies: 0
    Last Post: 07-12-2015, 11:03 PM
