After factory reset, data will not work?
  • Start date Start date
A
AC Question
After I had factory reset my ZTE Rapido, my data will not work. I can turn it on (meaning I can press the data button to turn it on and it will turn white saying its activated) but it wont actually connect. When I activate the data it will not show that the data is on by the upper right corner of my phone. (I have 4G, normally it would turn blue & have 4G next to it.) Nor when I try to connect to facebook or google, or the app store (providing examples, basically anything requiring internet I cannot use) it wont work.
Have you checked the Mobile Network Settings - Preferred Network Type (2g/GSM - 3G/4G LTE), and checked under Access Point Names that your networks apn settings are installed. Major updates can reset most preferences.
Also try removing the sim card for 20 minutes and re-install it and wait another 20 - 30 with everything turned on.
I've tried that as well and it didn't help. Honestly considering just spending money on getting a new phone. I've looked everywhere for answers and I cant find anything that works.
Was a solution to this found? I'm currently having this problem. Straight talk says they're going to send a new SIM but if that doesn't work i want to be prepared...or not have to wait 5 days to use my phone...
Had exactly the same problem. Signed into account, selected chat and Straight Talk representative had me back up and running with SIM card reset done by him.
I have the exact same problem. I factory reset a second time and the problem persists. I also modified the Access Point Names and that didn't fix the issue.
Has anyone found a solution???
Same problem I factory reset my note 2 but I took out my Sims card and now my data won't work I can press the button but I can't connect to my data the 4G symbol won't show up on my phone
[FOUND IT]
You just need to re-download the internetsettings. On my xperia z1 I can find it here: settings > networks > more > at the bottom "internetsettings" (download settings for Internet and MMS)
[FOUND IT]
Welcome as a new member and thank you for sharing. :)
I factory reset my samsung tab A and now it won't let me download anything. Does anyone know how to fix this problem. It tells me cannot establish reliable connection yet its using my wifi
Call your service provider. I just got off the phone with Straight Talk, and they wirelessly fixed my data. If that doesn't work, they will send you a new SIM card in the mail free of charge. I'd assume other service providers would be similar.
I have to constantly factory reset MMS just randomly stops sending or receiving. Sometimes I think companies do this to force you to buy an upgrade. I'm looking for APN entry info or MMS upgrades I can install. But I'll probably just get an upgrade... Or a virus from installing internet advice. Lol
Prince08900
