Is my Samsung Galaxy S4 Mini dead or is it my battery?
A
AC Question
Hello, as I stated in the question, I have a Samsung Galaxy S4 Mini and it was acting up lately...the screen was locked, then all of a sudden it got lit by itself. After some weeks after this, my phone just turned off and since then I couldn't turn it on. I took out the battery, put it again and the screen turned on for like 3 seconds, then it turned off again. Now it won't even do that, I plugged the charger and it showed the "charging battery" icon for 2 seconds and then it turned off again. I took out the battery and plugged the charger to the phone but it didn't turn on by any means...so I'm a bit worried that my phone might be dead. Do you guys have any ideas? Thank you in advance.
CVPONE VII
8
I've heard that if batteries are left uncharged for long enough, they get completely dead and empty of juice, so leave it on the charger for a few hours and see if that works.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Not just a few hours - at least overnight. I usually leave batteries like that on charge for 24 hours or more. If the phone doesn't do a precharge, and the battery is totally flat, you may have to buy a universal charger (they're under $10 at Amazon) - they precharge, so you can get the battery up to a few percent, then either let it finish charging or put back in the phone to charge it faster.
