1. ronald87x's Avatar
    I just finish installing twrp on my note 4 but going thought it I accidentally wiped system os. How can I fix this problem? Please help me with detailed answers. Im not tech savy.
    07-22-2015 10:34 PM
  2. Josiah23's Avatar
    Hey ronald87x the same problem happened to me on my old S4 after installing twrp, go on a PC and download something called "Odin", then search for " Stock "Carrier" Galaxy Note 4 Rom", download it, then put your phone into Download Mode and plug the charger to your phone from your pc. Open Odin and make sure Odin see's your device. Upload your Stock Rom to Odin which should say either "PDA" or "AP" and make sure an option called F. Reset, and Reboot are checked, now click start and wait about 10 minutes to complete. Take out and put back in the battery & go into Recovery Mode then Factory reset it & your done. If it doesn't boot then you may need something called a ".pit" file
    Sent from my SM-G900V using Tapatalk
    ronald87x likes this.
    07-23-2015 03:24 PM
  3. ronald87x's Avatar
    Thanks
    07-23-2015 04:59 PM
  1. HELP! Should I get HTC One M8 or Nexus 6?
    By Julio Cardozo in forum Google Nexus 6
    Last Post: 08-04-2015, 09:47 AM
  2. Screen to my Note 3 is locked, how can I get into it?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 07-23-2015, 11:11 AM
  3. Replies: 0
    Last Post: 07-22-2015, 08:30 PM
  4. Replies: 0
    Last Post: 07-22-2015, 07:32 PM
