1. AC Question's Avatar
    My battery on my galaxy s3 has been draining extremely fast, and not charging...When I plug it in to charge over night it says 100% in the morning, but the second I unplug it it goes down to around 36%...do you think I need a new battery? If so, how do I make sure I don't buy a bad or fake battery, but not pay high$? I'm going to try& turn it off and charge it, but this is really annoying. My iPhone never had this problem, but I like the Galaxy- the battery just sucks. I even close out all my apps, turn off Bluetooth and gps..is Amazon a safe place to buy a battery? What should I look for?
    07-24-2015 06:09 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It's most likely a dying battery. If you can't find (or don't trust) an OEM Samsung battery, then look for well-established brands of 3rd party battery, like Seidio or Anker. Only order for sellers with good return policies--Amazon is usually pretty good about this.
    07-24-2015 11:12 PM
  1. Replies: 2
    Last Post: 09-22-2015, 08:07 AM
  2. Samsung 6 vs Note 4
    By dazkil2103 in forum Samsung Galaxy Note 4
    Last Post: 07-25-2015, 08:03 AM
  3. Replies: 1
    Last Post: 07-25-2015, 12:03 AM
  4. How do I stop my Galaxy S6 Edge from being hacked?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 07-24-2015, 11:59 PM
  5. Replies: 0
    Last Post: 07-24-2015, 05:26 PM
